92 240sx transmission install problems
whyteboy
Car: 92 240sx coupe
im in the process of putting a new trany in my 240 coupe and when i line evrything up it doesnt go on all the way what should i do?
180fan
Car: 89 fastback
Wiggle it around. Either that or it could be getting stuck at the clutch disc portion, so what you might want to try is actually turning the crank with a long breaker bar to get the clutch disc to move while having someone push the transmission in. If you're almost there but not quite there, try using the bolts to help guide the transmission in.
