'92 240sx stereo wiring
Siffl
I just bought a '92 240sx se and i went to install my cd player and it didn't work at all. i checked the fuses, all good (unless the one labeled "audio" isn't for the stereo). upon closer inspection of the wiring i noticed that the wire that i think is the ground (from what i read) from the harness isn't attached to anything to the car. ie, there isn't anything that leads from the harness at all. i was wondering if that is my problem, and if it is, how should i go about fixing it. thanks
vancouverbc
Car: 1991 240sx
From http://www.the12volt.com.http://www.the ... ta...tereo
1991-92 Nissan 240 SX Stereo InformationConstant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Red/Blue Dimmer Red/Yellow Antenna Left Rear Front Speakers 4" x 6" DoorsLeft Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear DeckLeft Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
should be a black wire going to chasis.
BaconLuver
Car: 95 something...
this happened to me as well. just connect a ring terminal at the end of the black ground wire coming from the radio and attach it to one of the four screws that is near the shifter (manual or auto dont matter). someone once told told me that the shorter the ground wires are, the less chance of engine noise.
Florida240sx
I run all new wires for stereos.If someone palns to run an amp.I will not install radio until amp kit is wired.I like to run new speaker wires and everything.Only use antenna wires.
