92 240sx starter removal
GearHead21
Car: 1993 240sx coupe
ok so my starter crapped out on me -_- so now im going to swap it but im not too sure on how to. i searched but no one has a good description. its a ka24de just to make sure you guys know. please i need help its halloween and i want to drive around tonight!! thanks
scottydog
Car: 1992 240sx
the starter has two bolts, and takes 5 min to pull/reinstall. Not much to explain.
cleopp3
Car: 93 nissan 240sx
just two bolts like scottydog said one positive wire(plug) and one ground wire(nut). as well as the other two that are long. twist whole starter as u bring it out. tap it a couple times if you need to just get by. same happen to me had to tap with a hammer to start. hehe best just to replace.
dcwoah
Car: 1990 Nissan 240sx
the ground wire is such a pain in the ****ing ***. that lil pos ground nut is a 9mm.
