Second Shadow »
https://forums.nicoclub.com/second-shadow-u4629.html
Tue Aug 11, 2009 5:27 pm
I'm also having a little trouble with my speedo. For the most part it works fine, but when you rev past about 2500 to 3k RPM the needle shakes, and it also shakes intermittently past 50 MpH. It just seems to kind of wobble a little, about 3 to 5 MpH plus or minus.
I remembered seeing a topic that said most problems with speedo shaking were due to poor grounding but I couldn't find it. I did find an old post where the guy said on his car it was harmonic vibration. Now, I have solid engine mounts, and I don't remember when the shake started but it could have been around the same time.
is excessive vibration a common cause for speedo needle shake?
