214kka-et240sx »
https://forums.nicoclub.com/214kka-et240sx-u24476.html
Mon Jul 11, 2005 5:41 pm
ok, turn your car on, disconnect 1 at a time, spark plug wires, when you disconnect each wire at a time, the engine should shake alittle, for example, if you disconnect plug wire goin to cylinder #1 , engine shake, that cylinder is ok, cyl 2, disconnect and engine does not make a difference, thats your bad cylinder, cuz you might have bad wires, spark plugs, no comprestion, bad HG, or bad injector, so check for all this, i might be missing something, so anybody see wat i missed help me out.
