Ok, cylinders 2-4...the shaking changed. Cylinder 1, there was no change at all. Again, im not very car savy....what are you suggesting i change or repair?d!ck wrote:from skimming your issue it sounds more like a dead injector causing the car to run on 3 cylinders, thereby misfiring and causing the car to "shake."
my car did the EXACT same thing with this issue, it would balance out above a certain rpm and drive more smoothly, but still be running on only 3 cylinders. the fact that it happens at idle rules out the driveshaft. if it were motor mounts it wouldnt be intermittent.
what you need to do is let the car idle and unplug one spark plug wire at a time moving from the front to the rear replacing them as you go. if the idle gets worse, you know that cylinder is good. when you pull a wire and the shaking doesn't change, you know that cylinder has no fuel, spark or compression.
try it and post the results here.
Ok, so i bought some fuel system cleaner (techron) and some carb and throttle body cleaner...and an air filter, but thats neither here nor there. Anyways, after both cleaning treatments the shaking has gone down i'd say....30-50%. However, the tehcron didnt unclog anything. I was going to try and pull the injector out like you said and test it, but the screws are so corroded that they stripped in about 2 seconds...so now im off to figure out to get those off.xekushnr wrote:Yeah, d!ck's got it right, definitely a dead cylinder. Now that you're sure its not an ignition problem (unless its the dizzy, could be a worn breaker point) you just gotta make sure that fuel is going to the cylinder. The easiest way to test this is to pull the injector out, keep it hooked up, grab a empty water bottle and have a friend start and run the car for a few seconds while you shoot gas into the bottle. You want to make sure that fuel is coming out (obviously) and spraying in an even fine mist. I wouldnt recommend that you put that gas back in your tank unless the bottle was COMPLETELY dry before, because there will be some water left in the bottle and I'm sure you know that water does not compress.
lets say the spark wire tip is covered in a gooey material. it seems like its oil. what would that mean? sorry for the thread jack back im in the same positionaddisonblck wrote:ooo...damn was it covered in oil......carbon?wat was it cover in...? lol sumthing important to no.
it means you gotleveloneae86 wrote:lets say the spark wire tip is covered in a gooey material. it seems like its oil. what would that mean? sorry for the thread jack back im in the same position
