240FeVeR »
https://forums.nicoclub.com/240fever-u634.html
Tue Jan 08, 2008 2:29 pm
I'm pretty familiar around cars but before I go about replacing anything that will put a dent in my wallet I always want to get a second opinion!
My 92 coupe is running pretty rich, you can smell the overly rich mixture at a warmed up idle and fuel economy has become unacceptable. The engine runs very smooth and idles very well.
The car is VERY well maintained. Oil is fresh. Spark plugs, distributor cap/rotor, air filter are all brand new.
I've checked the oxygen sensor according to the FSM and it checks out to be in working order (changes from rich to lean more than 5 times within 10 seconds running at 2000 RPM in neutral). I have a Techtom btw. I tested the air flow sensor according to the FSM and it's working perfectly.
My only concern is the throttle position sensor, and I don't know how much this would affect fuel mixture. The FSM says the TPS should read 0.50V +- 0.2v closed throttle and 4.00V WOT. I was at 0.44V closed and then adjusted to 0.50, but couldn't get my WOT voltage to raise, it reads at 3.62 at WOT. Do you think this calls for a new TPS?
Thanks!
