NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Mar 13, 2005 6:04 pm
comfirm its bad by checking all three wires.the white is the signal wire it will very by amount of air flow going through it. the gnd wire black one should read .02v or less at all times, the black should be supplied voltage at all times and the white one should read around 1.3 to 1.5 volts at idle. if the white wire is higher or lower then that it is likely damaged. should be a signifacant difference like .2 volts either way.
