skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Sun Jul 30, 2006 5:19 am
I've posted my problem in other threads and I just got some anecdotal stuff.
I'm trying to diagnose my problems, here are the symptoms:
-steering wheel does not return to neutral (center) position if you turn the wheel about 20 degrees or so (if you turn it to almost full lock it does return to center but very slowly). You could actually make a simple left or right turn and it will keep going in that direction unless you move it back to center-reservoir levels normal-sometimes i hear a tiny squeaking sound (like a mouse) when i maneuver in/out of parking spaces. -when its cold in the morning and i start it up and maneuver out of my driveway it does make a short whirring/moaning sound when i move the steering wheel around but I'm assuming it's 'fluid noise' from the pump.-car has a perfect alignment, caster was set recently at 7 degrees ( i have adj. t/c rods) to see if it would 'help' but it hasn't.-car started to act like this after an autocross in June (its first autox)-everything up front is new or upgraded parts from my prev. S13: control arms, t/c rods, inner/outer tie rods, strut mounts, relatively new struts, etc.-very 'stiff' steering wheel but some mornings the wheel would be easy to move. It flucuates from time to time.
It seems to me the power steering is very 'weak' so i orderd a p/s pump just in case. I also have new p/s reservoir lines from Nissan i ordered last year but never got around to replacing because the slow, gooey leak i had last year suddenly stopped.
So I'm not sure if it's the p/s pump or the rack. I just installed swaybars wednesday night and now the car wants to pull right (slowly, not suddenly), so i took it to my alignment guy to see if something maybe got bumped out of spec but nope, everything was fine. I am at a loss. I have the p/s pump sitting here but i don't want to replace it if its really the rack or vice versa. People are advising me against flushing my p/s lines saying its 'pointless' but i think it may help if some valves in the rack are clogged or if the pump is clogged.
Help?
