s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Wed Oct 19, 2005 3:47 pm
i have done a few. yeah cover the cam with rags and stuff and put grease in the hole to make the metal chips stick instead of fly. you drill out the hole with the exact size drill bit the kit tells you to get. you want a decent bit. it will cost a couple dollars. do not use a wood bit. has to be for metal. go for high speed steel, titanium nitride coated, or something like that. then you tap it out with supplied tap. the tap is a helicoil tap and absolutely useless for anything else. this will require either a tap wrench or an adjustable wrench because the tap drive is square. then you screw the threads into the threads you just cut and break the tabs off.
walla.
