worangejuice »
https://forums.nicoclub.com/worangejuice-u33452.html
Fri Oct 14, 2005 12:08 pm
Wow, thanks for replying guys!
Yeah the speedometer count on the "smog" machine goes up to 15 then drops to no less than 14mph (14.3,14.7,etc.) The tester runs it in 2nd gear. So the tester says it can't be tested. I cleaned out the throttle body, far as I could reach in. There was some grimeyness;blackstuff. A problem was also that my 240 would be sluggish from 2k-3k, then it screams through the rest of the RPM's. I just got some new tools and I'm going to change the spark plugs and the wires. I hope it's that simple. I would like to 'test' the fuel injector's, but lack the knowledge. I also changed out the fuel filter to a z32 one. It still acted the same. I also read up on some "seafoam". Still need to read more into that. The car still runs like a little beast, but still feels like it could run better. Thanksworangejuice
