slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Thu Oct 27, 2005 5:04 am
Hi there, Sorry for the vague question, but it's hard to describe this in a topic. Basically when I corner hard, I hear something *sliding* back and forth in my sunroof. Whatever it is, I'll hear it sliding and then smack the one side. I'm pretty sure it's coming from the rear of the sunroof. No noise untill I corner the other direction(it has to be hard, not durring normal d/driving).
I only have *one* problem with the sunroof, and maybe this is a clue. When I go to open the sunroof, it will stop about half way. If I release the open button and press it again, it will resume. It does this *every* time. It will always resume if I press it again, and it doesn't sound like it's binding on anything(no extra strain noise from the motor). It just stops, like it thinks it hit the limit switch.
Any ideas? I'm looking at the FSM now, but I don't see anything that could be loose and slide back and forth like that.
I suppose it's not really a problem(except it not opening all the way the first time), but it's very distracting on cornering! I guess I should count my blessings that it doesn't leak or anything like that. I do see some water stains on the headliner, but I don't know if that's from it being left open once, or maybe the seals have even been replaced(no known prior history on the car). It has always stayed 100% dry for me.
Thanks for reading.-Jamie
