santa109 »
https://forums.nicoclub.com/santa109-u16064.html
Tue May 04, 2004 9:53 pm
I've got a recently acquired 92 240sx LE (VIN : JN1MS36S1NW117230), about 50k original miles on it. The car has been sitting in a garage for about 8 months, just been started once in a while but really moved much. Car works fine, maybe a bit sluggish, but that could be due to the air filter being clogged.
When I changed my spark plugs, there was oil in the spark plug well (mostly in one of them) and it wasn't at the bottom of the plug (where the tip is), but on the top part of the plug + wire. What do you think it could be?
Also, there's a rattle (sounds like somethings loose, or worn bearing sound) coming from the front of the engine, looks like it's coming from between the engine and the fans. Can be heard clearly when the hood's popped up, but not loud enough to hear it with the hood down. Any idea what could be loose or broken?
Thanks for helping.
