jonj0nn »
https://forums.nicoclub.com/jonj0nn-u137914.html
Sun Mar 14, 2010 11:18 pm
Anyone have a pic or know where the idle sprocket (Middle gear between the crank and the cam gears) is suppose to be set at with the crank at TDC? If I can not figure this out, I will be removing the main crank pulley, cover and all that other madness to check the chain placement on the lower sprocket.
Modified by jonj0nn at 2:19 PM 3/15/2010
