jbrown »
https://forums.nicoclub.com/jbrown-u62707.html
Wed May 02, 2007 5:41 pm
OK guys I'm going to be a little long winded as this problem is odd. Please don't tell me to search because I have and I've tried everything that previous topics have suggested for the most part, so I'm hoping someone can help me out through my own post;
I just bought a 92 240sx, BONE stock... It was a few days before I had the first hesitation happen. I was just driving and all of the sudden boom, the cars making no power. It felt like it was running on 3 cylinders. This car is going to be a track car, so I can't have this. So I do plugs, wire, cap and rotor. Seems to fix a lot of roughness issues, but then sure enough a week later, it's doing it again. On and off it keeps doing it, every few days and no real temperature/humidity similarities that I can see....
So then I change the fuel filter and air filter, again making the car a lot better all around. Sure enough, tonight (a week later) I drove the car about 60 miles, park, an hour later I need to run to the store and it's doing it again. I come back from the gas station, park it and then my friends get there... I start the car to show them and it's gone....
So the only things we can come up with are;
1.) It's randomly not getting spark, but on which cylinder we don't know... but it does feel like it's running on 3 cylinders when it does it, but then 3 seconds later it can be fine...
2.) An injector could be sticking, but again, you'd think it would do it more consistantly...
3.) The MAF is going bad, but also you'd think that wouldn't have 1 week periods where it was fine.
4.) Possibly the o2 or maybe a combination of things like TPS, IACV, or emissions BS...
5.) It could be getting no spark, but I've replaced all the ignition stuff besides the coil and distributor itself... possibly a bad ground?
6.) Maybe a timing issue? But you'd think that ALSO would be constant...
7.) The cat could be clogged as I did have a similar problem on an older car before, but with a clog usually it doesn't effect WOT situations as much as partial throttle... I do have an exhaust leak and the cat is probably original...
But yeah, we have a lot of ideas but I'm in no position to waywardly being spending hundreds of dollars hoping that eventually the problem goes away... This is my first 240sx, and I'm used to Honda's which have a lot of different components and are different animals in a way... The MAF thing is new to me, so who knows. Any and all input would be much appreciated as this car has to be ready very soon as the track season opens and I'm going to look mighty silly if I've got a fully prepped car that gets outrun by someone on foot...
I also want to add that the car idles a bit rough, on and off, all the time. But when the hesistation is happening, it idles especially rough. Like the shifter's bouncing all over the place...
Sorry about the friggen novel I wrote, but better to be in depth...
Thanks in advance for any and all help!
Modified by jbrown at 10:22 PM 5/2/2007
