LewMorris wrote:
1Noisy exhaust (no muffler mod), 2faint rotten egg smell (cat convert ?)
3Transmission sometimes won't go into gear from reverse to drive easily. Basically, after backing out, when you go into drive, it stays in neutral for a bit before going forward. (no clue)
4Idles very rough. Sometimes will dip down to 500 rpm.
5BIGGEST MYSTERY TO ME: The car rear end tends to sway back and forth. Real floaty. It's almost like it's shakin' it's *** when you drive. I just put a brand new set of tires on it, so that's not the problem. Any clues on this one would help greatly.
1 most likely
2 yes if it wasent gutted when the stright pipe mod was done.
3 could be a bad shifter bushing in the linkage. check your trans fluid level as well.
4 this could be a wide range of things. AIV,IACD, there are numours posts on this subject alone in here and primarily in 240 technical. do a search on rough idle you should get several results.
5 suspension bushings, bad struts in the rear.
