NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Nov 29, 2003 5:29 am
are you sure fuel pressure is ok? the ecm decides when to fire the injectors by a signal sent to it from the distributors crank angle sensor. there should be 2 feeds from the crank angle sensor to the ecm. basically one is for coil and one is for injectors. the ecm gorunds the injectors for x.x amount of milliseconds determined by inputs from crank angle sensor,mass airflow sensor, coolant temp and a few other. if you have no fuel discharge at all you should focus your checks to the crank angle sensor first then the mass airflow.
