alexh »
https://forums.nicoclub.com/alexh-u43553.html
Sun Jun 10, 2007 6:19 am
I have posted a few times on a hesistation problem and I recently noticed a problem with the idle that may be the actual cause.
When I'm driving the car and stop for a light(car is auto), the idle will of course settle down to about 700 rpm. Generally it's a very smooth idle.
However, sometimes, after 10 secs or so the idle will suddenly drop to about 550 and there is noticeable roughness also. When this happens, I nearly always get a hesistation when I take off.
I didn't notice this before bcause I have never seen it happen as far as I know when I just start the car in my driveway (even warmed up). It seems as you have to driving the car before the problem will show and even then it does not happen every time.
This does not appear to be a situation where the idle drifts down to 550 rpm or is hunting. It seems as if the ECM is activating a valve or something that immediately lowers the idle.
I'm going to run some of the checks in the manual but I was wondering if anyone has an idea what to check first.
Thanks
