alexh »
https://forums.nicoclub.com/alexh-u43553.html
Sun Nov 11, 2007 3:01 pm
Hi,
I have an inconsistent idle and cars stalls sometimes from a stop. I also noticed that the idle up that should occur when turning the wheel or turning on the A/C was inconsistent and I think this is what causes the car to stall sometimes, especially when turning from a stop (my car is an auto).
So I pulled off the IAA unit and cleaned it. Before I put it back on I thought I would electrically test the solenoids. The AAC solenoid behaved as expected but the FICD solenoid does nothing. Not only that but it has no spring action. The AAC solenoid has to push out to open the valve. However, it appears that the FICD solenoid must "pull in" to increase air flow. As installed now, just turning the IAA unit upside down will cause the FICD plunger to move and open the air flow passage because it is "floating" in the air passage. I can also verify this by blowing air through the air elbow.
So unless, I have some basic misunderstanding of how the FICD solenoid operates it appears it may bad and when that happens the plunger can float in the passage thus causing erratic operation.
Has anyone done any testing on the FICD when they cleaned the IAA unit?
I could care less about air conditioning but the inconsistent increase in air flow may be confusing things.
I have attached a pic of the FICD solenoid.
Modified by alexh at 7:50 PM 11/11/2007
