'92 240sx gets close to stalli while decelerating, doesn't pass MA emission test
rogue240sx
Car: '92 240sx hatch, '90 Q45, '10 WRX sport wagon, '73 Ford Gran Torino Sport
I've searched and have tried several things. The car use to stall during deceleration all the time till I replaced the whole IACV unit out for a new one.
Here's what has been done so far:-Plugs replaced with correct NGK units-new plug wires, cap and rotor-swapped injectors, fpr, and fuel rail because i had an extra set laying around anyway-New OEM O2 sensor-New CTS-replaced the entire AAC unit-cleaned and inspected EGR, operates like it should-disconnected AIV hose going into the air filter to ensure no exhaust was contaminating my MAF-Ran several cans of seafoam through the fuel system and about a half a can through the intake and a third in the crankcase oil-reset the timing and idle-Regrounded the shared sensor ground with heavier wire.-car has a brand new magnaflow cat. haven't done an emission test with that yet but i doubt it'll solve my problem as everything is a bit high(NOx, HC, and CO) .
As of right now the car runs fine other than the rpms dropping way too low while slowing down in neutral or clutch in, and it will still stall if I have a lot of accessories running and I go on the brakes hard. RPMs return to the proper 700 reading after a few seconds. Another thing worth mentioning, when I activate the A/C the RPMs shoot way up to aprox 1500 but they still dip pretty low during deceleration and just slowly rev right back up to the 1500 mark again after about 5 secs.
I'm sick of this problem and I just want to get it resolved. It's embarrassing when you have to restart the car randomly, and I'd like to be able to pass emissions without cheating if possible. I know I could just run some alcohol through it to pass but I rather have the damn thing running properly.
MaximA32
Have you checked the throttle position sensor? How about the MAF checked that yet?
