Ok, when I bought this coupe The speedometer/HUD were not working, he said the capacitor was probably gone, which is probably the case. After a few days all of the lights in the cluster stopped lighting up, so I decided to buy another cluster on ebay. I tried installing the new one and after I plugged it in I turned the parking lights on to see if the cluster lit up. The only lights that lit up were the 2 that light up the tach and clock. Also I noticed if I put pressure, like push on the cluster while it was in the car, that those 2 lights would go out and there would be no light.
So I took it out and decided to test it using sum wire and a jump box I have in my garage, constant 12v so why not. While testing I noticed the 2 lights for the tach and light work on a separate circuit than the rest of the illumination lights. But either way, sure enough all the lights worked fine while testing it out of the car.
I checked it again the next day in the afternoon and all the lights worked fine, cool right? Then later that night I went to show my friend that I got the lights working and what-do-ya-know, no lights lit up. So what is going on!?!?!?!?
My thoughts now would be maybe theres something wrong with my harness behind the dash.
Any advice from somebody more experienced?
Modified by S14Dorikin at 7:24 PM 1/24/2008
