NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Apr 25, 2006 2:06 pm
Usually dont need the fork or removal tool unless it is just rusted on. I usually use a long pry bar for leverage between the spindle and the control arm. The spindle is what the ball joint goes through and has the nut you must remove on the top side. While prying down on the control arm with the pry bar smack the spindle along the outside where the ball joint goes through. I suggest threading the nut on a couple threads to prevent yourself from slaming your hand on the asphalt when it pops out.
