Tims_240 »
https://forums.nicoclub.com/tims-240-u19154.html
Sun Jan 28, 2007 12:31 pm
I recently swapped my engine with another one. It was out of a friends car (he swapped an SR) and it ran fine before(the engine is a ka24de). Now after the swap I can't seem to get it running. All grounds are connected, I am getting fuel, spark, and my timing is correct according to the fsm. What will happen is I will let it sit over night, then go to start it up, it will start for about 3 seconds then die(which leads me to believe it is flooding itself because i smell lots of fuel). I have stabbed my distributor alot and I do know how to time it correctly, I have tried many teeth and twisted and turned it alot also, but still no luck. The process is to take off the valve cover, then turn the motor over via the crank pulley, then make sure the first cams are pointed straight out (facing away from each other) while having something in the # 1 spark plug hole(ratchet extension) to make sure it is TDC...Then line the rotor up with the # 1 spark plug hole on the cap. Easy as that, however I am still having no luck in starting it up.
Also, I compression tested all of my cylinders, the results arecyl. compression1 1352 1503 1504 130
now i did not have the throttle body open when testing, nor did I put oil in the cyclinders to see if rings are worn. However the FSM says the standard compression is 179 and the minimum is 151 and the most they are supposed to differ is 14 psi...
anyone want to take a stab at this?thanks -tim
