Axoure Dragonkin »
https://forums.nicoclub.com/axoure-dragonkin-u19649.html
Sat Dec 13, 2008 9:45 pm
1992 240sx automatic transmission
I recently cleaned the iacv and installed a new tps sensor. I adjusted the tps using instructions from the tutorials section which seemed geared towards a 5 speed install. It seems now my shift points are slightly out of whack. I set it @ .514 volts when I tightened the bolts down.
I can't seem to get an answer from anywhere except a brief mention in a post I read. (don't remember where)
Here is what I thought up when the gears in my head started turning while reading the FSM.
With the car being an automatic, do I need to adjust the tps so the soft idle switch is activated when I tighten the bolts down?
