alexh »
https://forums.nicoclub.com/alexh-u43553.html
Sat Jul 14, 2007 10:05 am
Hi,
been working on this problem for months - it is dangerous to drive this car and I may have to junk it if I cannot solve the problem.
Basically, this started about a year ago as a mild hesistation on starting from a dead stop. It has progressed to a very bad hesistation and recently the car barely runs for several minutes at a time. When it happens, it's obvious that the car is running extremely rich - I can see black smoke from the exhaust and I can smell fuel. Strangely though, it always idles even when it's in this mode. Then suddenly the problem completely disappears. The car generally runs great.
I have checked basically every system in the car according to the manual. The last thing I checked was the ECU. I opened it up and it looks pristine - no water damage or discoloration etc. Of course it could be that the ECU has an intermittent failure mode and in that case I may junk the car.
The only thing left that I can think of is injectors - Can injectors get stuck in the open mode? I'm doubtful. I have had injectors serviced/cleaned before on another car and I might try that as a last ditch effort.
Think I'm on the right track?
Thanks
