92 240 hatch trans issue please help!!!
quakejake13
Car: 1992 240sx Hatchback, 2001 Toyota Celica GT FOR SALE!!!!
So i recently replaced my clutch and flywheel and put it all back in the car. for some reason i cant get the car to go into gear, could it be my scyhros? (sp?) or could it be something with my clutch master cylinder? please help a guy out guys!!
Nfire247
Car: 1990 240sx (s14 Ka-T)
If it was working before you started the clutch job, then my first guess would be that your clutch isn't disengaging when you hit the pedal.
When you push on the clutch pedal can you feel pressure like the clutch is being opened/closed?
Check your slave cylinder to see if its moving the lever on the trans. like it should be.
quakejake13
decided to just pull the whole motor and trans and rebuild it. any idea on a good place to get a rebuild kit?
