92 240/Hatch...Engine light on. Need help locating the ECU
L_adan_C
Car: 92 240sx/ Hatch/ red
Can anyone tell me where the ECU is located so i can get a read out on the possible codes.
crackler
Car: ZOMG JDM TYT3
Under the passenger side kick panal. You will need to remove the door sill cover and unscrew a couple screws on the trim panal itself. then you will need to take out two 10mm bolts located at the top and bottom of the ecu, then flip it around so you can see the "front".
L_adan_C
alright thanks alot man. I've had the light on for a few weeks now. I kinda had a feeling it would be there.
