91QAZ »
https://forums.nicoclub.com/91qaz-u22978.html
Sat Feb 25, 2006 10:24 am
I have been trying to diagnose a stall + no start condition on my 91 Q. Thought it was FPCU/FP issues, but not anymore, so I'm starting a new thread. Here's what happened: I was driving at about 40 mph, car stuttered/stumbled and died. Have not been able to restart since. Chain guides have been replaced per service history, Q has 92,000 miles and about 100 miles ago (maybe less) I did an underplenum/KS job with hose replacements and shortly thereafter replaced FI #1. At the same time I did the underplenum job I installed a Robert/NICO ECU.
Diagnosis steps so far: 1) inspected FPCU for conductivity/burns = no problems found. 2) bypassed FPCU w/ jumper from harness to ground = pump hummed louder, but still no start. 3) Tried foot-to-the-floor flooded start procedure = no start. 4) inspected all electrical connections I could find in engine bay = found plastic connector above drivers valve cover cracked (wire from that goes into valve cover - probably to the coils?), but had wifey hold it together to ensure conductivity = no start. 5) installed fuel pressure gauge = when key goes to 'on' I get 46 psi with FPCU connected and 51psi with FPCU bypassed. When key is turned to 'start' (engine cranking) fuel pressure gauge needle bounces, but is in the 50 psi range.6) checked ECU codes = code 55 = no problemo (my arse).
I know my FP needs to be replaced, but based on the above, it that does not appear to be the immediate reason for my no start (unless I'm still missing something).
If I were in Atlanta I'd be towing this thing to T3, and may not be far from towing it to the dealer now, but don't really want to give up yet. I'm going to try to find an inductive timing light I can borrow and check timing and spark signal using Wes' method. any other ideas?
Thanks,Tom
