Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Sep 21, 2004 6:19 am
You can unplug the connector from the mounted FPCU and plug it into a test one hanging in the trunk . Make SURE you have a good ground wire alligator clipped to the metal case and a ground point for testing.
TPS= throttle position sensor 0.4 volts close going progressively up to > 4.0 volts WOT.
I'm not sure most [any] many technicans routinely do what I described and if they do, they may not know or remember what correct values* are based on rpm ambient temperature, barometer pressure.
* Absolutely correct values for the particular situation are not listed by Nissan [anywhere] they must be calculated for each case especially injector open time and timing advance vs rpm. Most important is the MAF voltage vs rpm.
I like to take 6-8 WOT back to back runs* and data log each portion 600-3500 rpm and 3500 to redline shift and 5500 thru shift to see the transmission shift time and return to 4500 rpm and progression up to 70 mph. This needs a special level SAFE place to conduct the testing.......usually not found near dealerships or the Police.
Pull over between runs print out data segments as approriate, review them mark them up and do it again and again .......then spend a few hours reviewing them.
