They're the same.timatt wrote:Can someone tell me whether the right bank power transistor is interchangeable with the left bank power transistor? I would like to swap them out to see if the problem folllows.
I suppose it's possible, but not likely - there have been a few coil pack failures, but I haven't heard of them taking out the transistor pack. Definately go back and check your connections... I assume you lubricated the o-rings on the injectors before re-installing? A couple of pinched o-rings could be flooding a cylinder or two on that bank, and preventing adequate flow to the other injectors on that rail.timatt wrote:Also, if I had a bad coil pack (i.e. short or something similar), could it take down all the other coils connected to the same power transistor?
The fuel flows through and around each injector in the rail between the two o-rings. A pinched lower o-ring would allow the pressurized fuel to bypass the injector and dump fuel into the runner. A bad upper o-ring would cause a leak into the engine bay.timatt wrote:How would a pinched o-ring result in flooding?
also, is there a diagnostic for the power transistor?
If you're certain it's not dropping pressure even after an hour or two then that's a fairly good sign you don't have an injector leak. Unlikely you would have 4 on one bank big enough to kill the spark. Speaking of which, can you check the spark with an inductive pick-up? I don't know if it would cause what you're seeing, but did you remember to ground the injector harness to the screw just in front of the #2 coil?timatt wrote:Heath:
OK, I see you point on the o-rings. I'mn pretty sure I don't have an upper o-ring leak, so if its a lower o-ring leak, would this result in a drop in fuel pressure? I tested fuel pressure yesterday and it seemed normal (i.e. around 42 psig). Also, when I turn the key on (not the starter), the fule pump runs for about 2 seconds, then stops. The system seems to hold pressure after the fuel pump stops. Would that rule out a leak in a lower o-ring??
Thanks,
timatt
