91Q....Not Quite Right
timatt
91Q; plenum job 5 days ago, with new hoses, knock sensors/harness and injectors. Car is now hard to start. This occurs both cold and hot. I have to use full throttle to get it to start, but after starting, it runs smooth and strong, but with a slightly low idle (I posted about that yesterday). The car did not do this before the plenum work.
Ideas? Advice?
azskygod
Two things come to mind. Either a vacuum leak or an injector leakdown problem. When I did my plenum, I missed the vacuum hose underneath the TB. Listen carefully for a constant hiss at idle. An injector leakdown problem may show up as excessive black exhaust smoke at startup. Good luck.
AZSKYGOD
timatt
AZSKYGOD:
I've looked for a puff of smoke on startup, but I haven't seen one. Tonight I test the fuel pressure leakdown. I hope that freakin plenum doesn't have to come back off!
timatt
See 91Q Low Idle for related post/info
