timatt »
https://forums.nicoclub.com/timatt-u11006.html
Mon Oct 11, 2004 6:33 am
I removed the injectors on Friday night and found out that three of the lower O-rings were damaged when I installed them. I replaced the damaged O-rings with new ones and installed them lubricated with sil-glyde. They went in easily, and now the car starts and runs properly and maintains fuel pressure when the engine is off. I learned the following from this experience.
1. Use a heavy grease type lubricant on the injector O-rings. The first time I installed them, I used a spray type silicone lube and the injectors were much harder to push into place. With the sil-glyde silicone grease, the injectors snapped into place quite easily.
2. I don't believe that it makes a difference whether you push the injector straight into its seat or whether you twist while you are pushing the injector in, PROVIDED THAT YOU USE A GREASE TYPE LUBRICANT ON THE O-RINGS.
3. You do not have to remove the plenum completely to acess all injectors. I was able to unbolt the plenum at the runners, remove the EGR connection and a few hoses, then lift the plenum up enough to access the injectors. Using this method, I was able to remove all injectors, replace all O-rings, then re-assemble in 2.5 hours working alone. This might be harder to do if the hoses were not brand new.
4. IMHO, the injector design for at least the early Q sucks and is not as reliable as it should be for a car of this expense and level of sophistication. Nissan should address this at their expense, or at least make the replacement injectors available at a REASONABLE price. Arguments regarding fuel formulation don't hold water in my opinion since I've got other older, much less expensive cars, with a lot more miles,that have more reliable injectors on the same fuel formulations that I'm using in my Q. I do not think it unreasonable for a customer to expect reliability for at least 100,000 miles, particularly when you consider what one of these cars cost when new. I started having injector issues at around 70,000 miles.
