tl91Q »
https://forums.nicoclub.com/tl91q-u19949.html
Mon Nov 01, 2004 1:25 pm
Hello:
About a week ago, my 91Q started having difficulty starting. This seemed to coincide with the weather turning cold.
After it has been sitting for 1 hour or so, it will not start on the first try. The engine will fire, and it sounds like it has started, but then it will die after about 1 second. I then crank it again and it will not start unless I floor the accellerator to WOT. The car then seems to run fine.
I took it to a mechanic to measure fuel pressure and he said all of his measurements were within spec.
I then took it to the local Infiniti dealer. They said it was a bad MAF sensor. They replaced it. I got the car back from them today (they had already started it when I got there) and it still has the same starting problem after it sits for awhile.
I don't have a lot of confidence in the dealer. Any ideas?
Thanks,TL
