91Q AC dead - help
yidal88
Car: 91 Q45 , 99 Pathfinder , 00 S2000 , 03 M45 . 04 Ducati 749S
was low on charge , AC worked but very weak . My long time mechanic evacuated , charged it to the correct weight , checked everything , took it for a test drive , even sticking termometer in the vent . came back said everything is good - working fine . I get in the car driving off - AC blowing hot air . Just 5 minutes before worked fine ??? . Came back , they evacuated , charged 5-6 times , looked at everything - nothing , blowing hot air . The compressor is engaging , clutch seems OK . I think he said 'low pressure reading high' or something . Is it expansion valve or dryer ? Any ideas ?
benemorius
Car: s13, s13, eg, e36
Why can't the mechanic diagnose the problem?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No mention of drier replacement? Can't be properly recharged without a new one. Any leak tests performed?
Aussie Q45a
Car: '89 JDM Q45a, Skyline GTR, '95 Fairlane. MB Winnebago
What Code do you get from the self diagnosis?
Is the high/low pressure switch defective?
qship96
Car: 1996 Infiniti Q45
maxnix wrote:No mention of drier replacement? Can't be properly recharged without a new one. Any leak tests performed?
complete nonsense! DRYER does NOT need to be replaced to evac-recharge system.
benemorius
qship96 wrote:complete nonsense! DRYER does NOT need to be replaced to evac-recharge system.
If you bring a car to me with a low charge or in an otherwise questionable condition, hell yes it does. When you don't know, you replace it.
Q451990
I would say that it needs to be replaced whenever the system is opened. For a simple evac/recharge without unbolting anything - I would say a long vacuum and recharge would be fine...
Heath
benemorius
Agreed, BUT since you don't always know what has or hasn't happened to the system, you have to play it safe. For me, playing it safe means replacing the dryer any time I suspect even a slight chance that the system may not have been properly worked on. Low refrigerant is reason enough for me. For all I know, all the refrigerant leaked out and the system was recharged with one of those cursed interdynamics kits before leaking a bit more.
yidal88
Well , we did the long evac before recharge few times , but did not help . still just blowing outside air in. What could have gone wrong in 5 minutes though? I'll try getting the self diagnosis code . still weird
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:I would say that it needs to be replaced whenever the system is opened. Heath
Yes, and also if it is aged as its function is to trap any moisture in the system.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
benemorius wrote:Agreed, BUT since you don't always know what has or hasn't happened to the system, you have to play it safe. For me, playing it safe means replacing the dryer any time I suspect even a slight chance that the system may not have been properly worked on. Low refrigerant is reason enough for me. For all I know, all the refrigerant leaked out and the system was recharged with one of those cursed interdynamics kits before leaking a bit more.
Leaking is always an indication of contamination from air. Pressures will equalize.
