911 I need help on my s15 swap
nissandet240
Car: My car, DJ sytem, PC's and Technology
OK let me break it down.I need to know location and color wires for the following parts:fuel pum( location of the wires I know the fuel pum is located inside the gas tank ok)speed sensor. color wires and where are they located. I bough a s15 clip and you all know that these are chop off from the half and so all wires, i need to located those things mentioned abobe, plus somany others but that will be later.i still havent pull anything apart yet, Im comfuse on how to due this, i guess maybe i shuold number bac hoses and staff.
1991240xs
no idea on the wires for the fuel pump. When you're doing this, I suggest you take lots of pictures of Everything....not only will it help you out when you are wondering what that wire went to...it will probably help the many others who will end up doing this swap. I would get buddy buddy with someone from japan that speaks Enlish...or maybe learn japanese? This isn't going to be an easy swap for you..just take it to dauntless..give in and pay the install charge..you wont' regret it-...(or whatever shop is closest to you - unstable or others-
nissandet240
questin does any one know if all s15 have the pillar gauge?what does it gauge?and wich are the wires?any help.....
89sxRCR
Car: destroying self esteem
whyd u buy the s15 front clip without a clue how to install? Take it to a pro man, there arent many s15 install faqs.
Daunttless
Quote »there arent many s15 install faqs[/quote]There aren't any.
89sxRCR
lol i kinda figured but i wanted to cover my bases there in case somebody had one..
nissandet240
well there was a time when no one knew anything about the sr20 or CA installs in to the USDM s13 and s14.i guess this is the way we make the 240 Forums more interesting. just imagen if everyone would go for the same boring thing. it would be lame. my opinion.
Daunttless
more power to you. : )
89sxRCR
Quote »well there was a time when no one knew anything about the sr20 or CA installs in to the USDM s13 and s14.[/quote] um actualy the s13 sr20 was factory made in japan, so the s13 in north america obviously could have swap with the japanese version. Same with the CA. Now the s15 engine was never meant to be in a s13 or 14 chassis, so your talking about something a lot more complicated, and since u already bought the front clip, ur screwed unless you either bone up on engines or fork out lots of money. Incidently installing the s15 yourself will still be pricey. My opinion? Sell that s15 front clip for a good amount and juice up a s13 sr.
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
Or get an RB25DET from either Night or DaunTTless. :) Same price as a juiced up SR
