1995240sxSE wrote:cpv port
PCV. haha.
That much oil shouldnt come out of your PCV. I've ran open PCV ports lots of times and that never happens unless you've got some serious blowby going on-- i.e. blown rings.
...Even still, that wouldnt explain oil on the spark plugs.
Blown headgasket usually means you burn coolant, not oil. Generally if this is the case you can see oil in your coolant or coolant in your oil. Thats why I asked that question... If your rings are really bad (or if youve been cranking alot and no firing) you'll have a lot of fuel in your oil. Another thing to check.
The most likely place for oil to come from is either that spark plug gasket (maybe it was offset somehow, or perhaps it is cracked?), or through the rings. Rings seems more likely given the blowby out of the PCV and the compression test results. Have you redone the test yet? Try pouring a capful (bout a tablespoon) of oil down through the spark plug hole and doing the test again. If that bumps your pressure up, its most likely your rings.
