Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Thu Jun 07, 2007 6:44 am
Yep.. your 91 and the 93 'vert were identical twins when they rolled off the assembly line. The 'verts were redirected to ASC where they were then converted into droptops.
So other than the obvious differences (convertible top, pump, rams, frame) and the noticable differences (frame reenforcement, doors with seatbelt pillars, crappy interior panels, unique rear quarter windows, etc..).. the two cars are the same.
The 'verts got ABS size rotors and pads in the front to help compensate for extra weight. They got some hefty bracing across the undercarriage to compensate for the lack of a roof. There are a few other things...
The engine/trans is the same between models. It was reported that most 'verts didn't come with A/C.. but I'm seeing lots that do have it. You can pull it out of the coupe and replace it identically into the 'vert. Not sure if the 'vert has the A/C pump bracket still bolted onto the block or not.. you'll have to double check that.
Otherwise... body, suspension, engine, electrical, etc... all identical between cars.
