'91 TT 2+0, stock rear end - What wheel setup for 15 inch Mickeys?
Vadocity
Car: 1991 300ZX TT - Turbo LS Swap'd
Alright, I've spent too much time trying to find a hard answer for my coming wheel setup. Does anyone have any offset/spacing recommendations to fit a 15x8 / 15x9 wheel with 275/60/15 Mickey Thompson ET S/S tires?
I've found and discussed a lot of recommendations for the rear setup, but everything I've found so far is for 2+2 model 300ZXs. Before I pull the trigger on wheels, I figured it would be worth asking the club in case there was anything obvious. Car is being setup as a roll monster.
Leaning towards 15x8 wheels with 5.5 or 6.5 spacing if either of those would work.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Exact same offsets should work for 2 seater and 2+2. The suspension setup is identical and that's where you'll typically run into problems.
