1) Make or buy your own brake bleeder catch can. See below awesome image.
2) Open your brake reservoir, top it off.. and keep topping it off as you drain the fluid. Typically don't exceed max line.
3)Pump the brakes at the driver seat to try to distribute any air in the brake lines.
4) Start with the furthermost wheel from the brake reservoir, attach your catch can hose to the nipple.
5) Crack open the nipple and hold the hose such that it has a vertical up slope from the nipple(see below image). The goal is you want to watch the fluid climb up the tube. It also help reverse seals the nipple from bleeding air. Gravity will move the fluid for you. And with the tube vertical you can watch both the color and air bubbles;)
6) If changing fluid drain until you see a noticeable color change and you have at least 100 to 200 ml of brake fluid in the bottle. Or if you are just bleeding air, just stop when you think the air bubbles stopped.
7) Do step 3 .. 5.. 6.. again. And as much it takes until you feel you bled the air.
8) Remember to fill the reservoir.
9) Move to the next furthest wheel and repeat 3, 5, 6 and 7.
10) Repeat step 9 until you run out of wheels.
