91 trans swap question
yoster4
Car: 1991 240sx
Hey, im kind of new to this stuff.but i want to swap my auto trans for a manul.quick question...
i have a 1991 s13 hatchback
what year transmissions will fit? only 91-94? or will other years fit too?
thanks for any replies. =)
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
First off, welcome to Nico. There is a wealth of knowledge at you fingertips that can be accessed through the search button at the top of the page. Start off with this for the swap information you are looking for:
http://www.240sxtech.com/
Good luck man!
yoster4
Car: 1991 240sx
i saw all those. ive read most of the links on there.
all i was wondering is if the trans has to be from a 91-94 or can it be any car with the ka24de?
yoster4
Car: 1991 240sx
anyone?
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
You need to source a transimission from an s13, but an s14 trans will work as well (sensors are different b/n the two). IIRC, you only have to connect the reverse sensor, obviously, for the reverse lights to work....not sure if not connecting the other sensors will result in CELs. NOTE: you will definitely need an s13 speed sensor. Also, the s13 and s14 bellhousings are different. If you get an OBDII s14 bellhousing, I will be more than happy to swap with you . Not sure if you have a vert, but if so, you have to connect the park sensor to allow the top to work. If you have any more questions, feel free to e-mail me at the address in my profile or buy the JDS performance 5 speed swap video. Josh, covers just about everything in the vid and it is a great source to refer to
