91 stanza problems
avs0730
hello everyone i am new to this site. ok i'm having problems with the stanza its a 91 xe automatic. i have it for 4 months now. i was taking for a 40 miles a day to work and back no problems in the summer. about 2 months ago the car die just before the expressway on the way home. my wife pick me up and took me home. so the next day i took my other car and went to the stanza and see if i can start it up. it did and i drove it home. now i thought it was a fuel pump so i change the fuel pump and filter and also did a tune up. now the car is doing the same thing. it could do it when its cold or when the cars running for 20 mins. need help. the cars has great heat and air condition. also can i put a sr20t in the 91 stanza thanks.
avs0730
please help my stanza
NISTECH
Check for oil in the distributor cap.
avs0730
NISTECH wrote:Check for oil in the distributor cap.
i did that and no oil. could it be egr also the idle jumps up to 1500 - 2500. please help.
NISTECH
did you look under the plate below the rotor? thats where the oil effects the crank sensor.If your idle is speratically jumping to 1500 the first place i would look for that is the tps adjustment. if the hard idle contacts are opening that will make it jump up.
avs0730
would the tps would make it the car to stall out.
NISTECH
no
avs0730
could it be the ecu
