RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Sun Apr 27, 2008 8:57 am
It will work just fine. You will have to extend the knock sensor wire and use the distributor from your 95 motor as its OBDII and has an internal coil on the distributer, then 91 motor is OBDI. Everything else is plug and play.
