91-s13-transmission alignment issue?
yodc
Car: RMS13 '91
Okay, so I tried searching, and have found nothing about this, I also called a few people and they think im on drugs...
but i swear its happening
the best way i can explain the problem is that my shifter is not properly aligned. First is around where 3rd is on my friends s13 and 5th and reverse hit the trim when i go into those gears.
I wouldn't mind really, but its starting to crack the center console bezel. :
I recently bought the car and have no idea of its past history.
any input/suggestions are appreciated :
slociv
Car: A shop full
you can loosen the 4 trans mount bolt and move the transmission, also check and make sure the engine mounts are properly aligned in the subfram, and lastly what kinda of shifter is it?
yodc
Car: RMS13 '91
thanks, i wasnt aware that there is adjustability in the transmission bracket.
Its the stock shifter btw
nissanman04
Car: '90 240SX, '95 Subaru Legacy
yodc wrote:thanks, i wasnt aware that there is adjustability in the transmission bracket.
There really isn't adjustability in the transmission bracket...
yodc
Car: RMS13 '91
so the transmission doesn't bolt into the bracket, it just rests on the the bracket?
scottydog
Car: 1992 240sx
I can't imagine transmission alignment causing this. Bent shifter/linkage? Besides shecking the engine/transmission mounts you could pull the shifter out and inspect. I don't think there is any external linkage adjustments to be made.
drft204
Car: 98 VW GTI VR6, 89 240sx Coupe
what kind of drugs are you on lol
