Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jan 30, 2014 7:13 pm
Something sounds like it's shorting the system then. The power should go battery -> fuse -> cluster -> gauge -> sending unit -> ground. If it gets grounded anywhere between the sending unit and the cluster, the system will see no load on the signal wire and assume the tank is full. Make sure there aren't any rub throughs on the harness. Your wrestling with the harnesses might have caused an unintentional contact somewhere. Also double check all the grounds from the cluster as well. Other than that, you can check the fuel sending unit is functioning properly by checking the resistance across the terminals. It should be low resistance for when the tank is full (float up) at around 4-5 ohms, and 78-84 ohms when the float is down.
