check your rack bushings first and replace htem. Theyre not real hard to replace and are cheap to buy...rasrx7 wrote:ahh ic..kool.. i have to get under it and see how i can resolve that...is there ne where on the forum you can post the link on how to do all that? thanks again...
Only if it breaks or if you otherwise lose control.rasrx7 wrote:can driving around like this be dangerous?
Sorry to dig up an old thread but.....Q45tech wrote:Steering rack mounting bushings fail and the rack assembly slides back and forth.
To regain perfection you must lower the tie rod end via spacers or longer units equal to the amount you lowered the body to return the toe bump steer angle to correctness.
The rack being attached to body is now lower than the tie rod end.....tie rod arm upslopes.
no... ive been driving with the stock tie rod lengths for years and its been fine. More applicable on cars that are SLAMMED...anlasak wrote:Sorry to dig up an old thread but.....
Does that mean that if the car was lowered 2" then the tie rod end must be lowered 2" to match?
Or is there some set ratio?
The '92 has a bad shimmy between 40-60 mph and especially when cornering in that range.elwesso wrote:no... ive been driving with the stock tie rod lengths for years and its been fine. More applicable on cars that are SLAMMED...
