'91 Q45 transmission will work in which year range of Q45s?
Ford Falcon
Car: '88 300ZX (to transform into a 450Z)
Hey viewers,I have a '91 Q45 donor car that I'm in the process of parting out. I advertised the transmission and I had someone call the other day asking if it will work in his '96 Q.
I called a local Infiniti dealership and was told that the electricals are different between the '91 and the '96.Does someone have a definitive answer on what year range the '91 transmission will work on?If not the electricals, are the mechanics and dimensions the same?Can I simply remove the wiring harness and use the one from the '96?
Cheers,
Dave
Q45tech
90-93 have the same gear set and 94-96 have a diffferent 1st and 2nd gear set.
Q451990
So yes, it should work - but with different gearing it will feel different. They are physically the same shape - just different gearing.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:So yes, it should work - but with different gearing it will feel different. They are physically the same shape - just different gearing.
Heath
TCU will not shift at the right points at redline without a compatible 1993 TCU as it will be expecting the numerically lower 1st and 2nd gear ratios of the later transmission.
1996 G50 is OBD II, but I don't know how that affects the wiring harness for the transmission and TCU.
Modified by maxnix at 9:47 AM 11/6/2007
DrewQ45
Car: 1990 Infiniti Q45
Rex
Car: None
I have a 92 in my 95, it bolts up and connects.
