mastahblastah wrote:I have a '91 Q45 daily driver, 270k+ mi. transmission has a shudder between mid gears that improves as it warms up. Any concern here? What's the most likely cause/fix?
Welcome to NICO. We do need some more maintenance history on your Q before making a guess. Is this the original transmission or a replacement? It could be something as simple as needing a flush and filter change (clogged internals) to an ailing torque converter.
I had the dreaded transmission shudder in the 90Q I sold a couple of months ago. It happened right before shifting at about 35mph (sometimes), 45mph and 55mph on flat roads and inclines, never on the downhill. I attributed it to an ailing torque converter from a transmission that started in 2nd gear all its life (for smooth acceleration from a stop) rather than the conventional 1st gear (jack rabbit) start.
I was able to minimize the shudder initially with Lucas Transmission Treatment and later with a flush and filter change. Depending on your mileage a new transmission mount and exhaust hangers would also cut down on the vibration. In my case the transmission shifted great in all gears so the shudder was more of an annoyance and not a must fix item.
