91 q45 trans help please
revhead
Car: 1991 q45a
Hi guys im new here and ill post pics of my beast as soon as i work out how lol,its low on coilovers running 18s,dark tint,dyno tuned 245kw
auto on the beast feels great but when i put it in first or second it wont compression down,goes in smoothly if i touch throttle but if i take off throttle falls out of gear.
shifts great up through gears and fluid clean and unburnt.
any ideas appreciated.
qship96
Car: 1996 Infiniti Q45
compression down? What are you attempting to communicate to us?
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
I think he's saying it won't engine brake. What speed are you downshifting at? If you're downshifting at to high of a speed, the transmission won't go into a lower gear so you don't over-rev the engine.
revhead
Car: 1991 q45a
yeah sorry thats a better description of problem it wont engine brake.
Wont engine break at any speed,starts off in first if I put it into first as it should but if I release throttle drops into neutral???
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
ATF white paper towel test? Maintenance history?
revhead
Car: 1991 q45a
Yeah done that fluid is clean,not brown or burnt smelling.
I dont have much history on maintenance but car is in top cond for age and auto feels great unless trying to engine brake.
Could it be vacuum or tps sensor related? The tps sensor went on a jeep i had and that 'fell' out of gear.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Does the "TRANSMISSION MALFUNCTION" message come up in the screen that says "OK" every time you close the door?
