I just want to make sure I wasn't confused about this... there are 9 accumulators.
When I asked for a quote from Keith, he told me that it was $275 per accumulator ($2475 total). He then refunds you $100 per accumulator when you return your stock accumulators ($900 total). Thus, the total cost for the full set of accumulators was $1575 plus shipping.
Still a significant savings compared with dealership repair pricing... but, a lot more than $900! If misunderstood Keith's pricing, please correct me.
Kirby... congratulations on your purchase. I just purchased my first Q (a '91 Q45a with 128K for $2100) about a month ago, and it has already been an adventure. As someone who knows next to nothing about anythhing automotive, the task of maintaining a luxury automobile seems a bit daunting. However, the people on this board have forgotten more about the Q than most Infiniti mechanics know. Do lots of reading, ask lots of questions. I assure you, anything you encounter has already been solved by someone else before you! To help make some of the reading easier, go back over the past 4 weeks of posts and find the threads where I started asking questions, since most of the questions will probably be helpful for your car as well.
Specifically...1. I am sure you have already started reading... but, definately read anything you can find. Do a forum search using "active suspension". Also, check out
http://www.q45asuspension.com and
http://www.q45.org. Sounds like someone has already pointed you in the direction of new accumulators.
2. I haven't had this problem, so I haven't done any reading on this subject yet. However, I can tell you that with the Active you need to be very careful about how much dirt and grime is getting in and near your suspenion components. You will find out more when you do some more reading.
3. My P/S has a tiny leak as well. Apparently its pretty common in these models for there to be small leaks. Most of the info I have found seems to conclude that the problem isn't a super high priority. The standard reccomendation seems to be the following: Do a P/S flush (you will find a recent thread on this very subject) using the full mechanical or turkey baster method, and follow up by making sure you keep a close eye on the level and color of the fluid. Apparently, by using Mobil1 (or other, depending on who you ask) ATF in your P/S, this process will get a higher viscocity liquid in to your system and will therefore may help with the leaks. I know you said that all the fluids were just changed... but, if you didn't change them and you didn't dictate what fluids were going in, I think people are going to tell you to do it again.
4. Wes helped me by doing a transmission flush on mine about a week after I bought it. And, my transmission acted completely goofy for about a week after that... now, however, it seems to have smoothed out a lot. I don't know if/how that little bit of information might help you, but now you know.
5. My suggestion regarding the timing chain guides is to do as much homework as possible. If you can get a vehicle service history, do it. If you can find someone with a borescope (I think I spelled that right), you may be able to see inside there without taking the engine apart. If you can avoid the frustration that Wes and I recently endured, it is worth a little extra time and money. Wes volunteered to help me change out my guides... proceeded to tear my engine apart... only to find out they had already been replaced. Doh!
Email me at
[email protected] and I will send you an electronic copy of the FSM.
Hope some of this helps...
