Q45tech wrote:"Purchased for a mere $1,500 "
Because it will cost $5,000-$9,000 at retail to restore it close to fully functioning as new, not counting external cosmetic or seats/steering wheel.
However with a combination of do it yourself, hours/months of study, trained aftermarket technicans, and discount INET parts you can probably reduce the cost by 25%-40%.
Really depends on your personal standards. Since you never drove one brand new, the same as 99% of current owners [90-93] in US. It is hard to tell how bad it really does drive, brake, handle, ride........cool in summer, or visualize [pitted headlight lens and windshield].
You'll find almost ever possible repair on this site.
A 14 year old [192,000 mile] car will have lots of wear and tear issues..........the main question is the quality of the replacement engine [where it came from as no owner would pay the full price of a new engine ~~ +$12,000] and how much prep work was done on it.
How many miles on the current replaced transmission, the drive shaft.
Seriously doubt the previous owners spent $22,000 [plus engine swap] on maintenance and repairs in the previous 14 years.
Once you get it right, the cost is roughly 15 cents per mile thereafter, compared to a Honda Civic which cost 6-7 cents per mile to maintain to standard. Gasoline is currently approaching 13-14 cents per mile in some States.
Cars are sold because the owner gets a $3,000-$5,000 estimate.
Just so you know the facts. Only 3 technicans [out of 72] I know in 9 dealerships in GA and Florida drive 90-93 Q45 even though they could do the labor free [spare time/after work in dealershop] and purchase parts for half price at dealers cost...........these guys all make $52,000+ per year.
Ah, but that is the exact point that Dennis is making! Once you do restore it to fully functioning as new, you will be greatly impressed by its real performance and awesome "all-roundedness" and will not bother with getting another brand new car.’91_Q_45 wrote:First off, im am not at all trying to "restore it close to fully functioning as new" All im trying to do is make it a reliable daily driver, until I can afford a brand new car.
I think the other point of Q45tech's post is that as a complete operating system, if you let one part of it become dysfunctional, it will compromise the longevity and performance of the functioning components.szhosain wrote:
Unless it is another Infiniti with the same pedigree (the reason I now have an M45)!
Welcome to the forum - regardless!
Z
Im installing an aftermarket stereo(splicing, no money for harness), so i need to know what wires perform what function(I already got the power hooked up, and the door speakers. I need to hook up the memory, antenna Ect.....). The door speakers are already installed and the wires are re-routed. The rear speakers are gone.PoorManQ45 wrote:Back to the original post.
When/if you install an aftermarket HU, are you going to use the Bose amps(if they're good, of course), or are you going to bypass them?
If you are going to be removing the Bose equipment, I do not understand why you wanted a wiring diagram. All you are going to have to do is:
Remove Bose crap, I mean stuff .
Buy install kit that allows you to use a 1 DIN HU in double DIN space.
Buy HU
If you would like to keep the functionallity of the antenna, you are going to need an adapter. Someone on here should be able to direct you to a making of one.
Remove center dash/console cover
Run power wire from an ignition switched source, or run it straight from the battery if you'd like it to operate after the key is out.
Run negative wire directly from battery to HU.
Ground HU to frame, or a ground wire in the area.
Remove front door panels
Remove rear deck. The back seat must be removed to remove the rear deck. Do not try to remove the black metal covers.
Run wire from HU to the doors and to the rear deck
If you are going to be installing an external amplifier later on, it would be wise to run your RCA cables now.
Install new speakers in the "pods" in the door. Some modification may be needed.
Install new speakers in rear deck.
Wire everything properly.
Turn key to accesory position, check to make sure that everything works properly. If it does, continue onto the next stage. If it doesn't, go back and check all connections.
Reinstall all panels that were removed.
Turn car on and enjoy the newly found quality that your aftermaket system should provide.
